Do's anyone here have the definitive answer to which spark plug should be used on the 6304 engine. I have had conflicting advice about the use of double/triple tipped plugs but these cannot be adjusted and they have a much bigger gap than is recommended for this engine.
I am currently using a set of Volvo triple points which i acquired from ebay but due to ignition system fault codes recently has got me to wonder if they are in fact the correct plug. Being "old school" i prefer the single tip plug that i can adjust if required. Thanks for any advice.
1994 960 3ltr Spark plug choice
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Absolutely Not...there are two answers in Volvo's pocket book!father ted wrote:definitive answer to which spark plug...6304 engine.
For high speed driving - Volvo 3517629
For normal driving - Volvo 3517980
Bosch - FR 7 DC/FR 6 DC
Champion - RC 9 YC/RC 7 YC
I think above numbers translate to
Bosch FR7DC
Champion RC9YC
precopster
- Year and Model: Lots
- Been thanked: 128 times
The misfires are more likely failing coil packs which are beginning to have broken insulation. Check the boots for white powdery marks. The plug choice is not super critical on non turbo whiteblocks.
DEWFPO
- Year and Model: 1998 S90, 1995 964
I've used the standard OE Volvo (Bosch) tri-electrode plugs in our 1995 964 and 1998 S90. They've worked splendidly. If you need the P/N I can get it off a pack in the garage.
DEWFPO
DEWFPO
"Trying to Enjoy the Journey"
- 1132 Views
Last post by father ted
- 827 Views
- 1755 Views
- 3041 Views
Last post by Roger_850T
- 779 Views
