1998 V70xc Bluish white smoke when I open up throttle
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
I recently purchased another Volvo, a 1998V70xc to add to our small collection('04 XC70/'96 850). I got a sweet deal on her cause of a few minor issues(key was stuck in ignition/needed battery/bald front tires/oil filler cap needed new gasket). Anyway some lines/hoses near rad have oil seeping from them, they look like oil cooler lines and the turbo air intake tubing. The PCV system definitely need to be serviced. I put new double platinum spark plugs, Mobil1 5w30/Mobil 1 oil filter, new battery, front tires and I put some seafoam into the gas tank. It will blow smoke when I get on the throttle.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Deal with the PCV and it will likely clear up the smoking problem. If that doesn't clear things up then do a compression test. If you have low compression and smoking then it may be the piston rings.
Ben850
Been thanked: 7 times
Post by Ben850 »
That will make smoke until the Seafoam is run through.
I enjoy the smoke while knowing it is harmless.
93 octane in the tank next fill.
It has an interesting smell as well. Somewhat sweet, with a texture of elderberry?
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
What brand spark plugs are those? In any case, these cars run best with OEM Volvo plugs.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
shiloh51933
850 LPT wrote:What brand spark plugs are those? In any case, these cars run best with OEM Volvo plugs.
Volvo plugs
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
shiloh51933 wrote:... I put new double platinum spark plugs...
The Volvo plugs for a turbo are single electrode, not double.
Ben850
Post by Ben850 »
Collection is a nice way to explain it.
What color is yours, by the way?
I had added the same to my collection, hoarding? I don't know. I did not need another, but there seems to be an abundance of the '98 XC lately.
I believe this must be their time for passing from the pragmatic existence.
I am having fun with these cars at the moment.
They have inspired an old hobby, as well as a couple nice vehicles I am keeping all to myself.
Another day in the drive.
Ben850
Post by Ben850 »
Simply Bosch Super Copper for each. Gapped @ .026. Let them burn and replace.
When I say "replace", I have not had to even do that in the last four years. Re-gap may be a useful term.
The cars seem to love them.
In my experience so far.
Not expensive either, at around $2 EA.
To address the condition this thread calls for, bluish white may be a puff of oil coming from either the turbo, valve seals, other possibilities.
Was the engine idling for long, fully warmed to running temperature? these are considerations as well.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
If you ask me 5w-30 is pretty thin oil for these cars and for climate you are in.
5 or 10w-40 should be used in these cars with a lot of mileage on the clock.In the other words...Synthetic 5w-40 for turbo and semi-synth 10w-40 for non turbo for moderate climate all year round.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
shiloh51933
That's what the factory specs call for, my understanding is double platinum means there's platinum on center and ground electrode. My factory Volvo plugs for my n/a 850GLT have 3 side electrodes and all spark plugs have a center electrode/side electrode...so I'm confused about your statement that turbo Volvo plugs have single electrode.
