Hello Everyone,
I recently bought a 1991 240. I've noticed a valve cover gasket leak near the firewall. I fully expect to find the cause to be a gunked up flame trap. My question is after I clean/change the flame trap and replace the valve cover gasket, do I need to do anything about the possible sludge build up in the motor? I've always read not to do any kind of anti sludge flush on older engines. I just want to clean what I can safely clean in order to optimize performance. Thanks.
1991 240 PCV flame trap valve cover leak
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Increased blow-by pressure can bring about leaks....also, at firewall side of head, there is a plug, and if this plug is dislodged via increase blow-by, it will cause an excessive oil leak.vcowens wrote:1991 240....valve cover gasket leak near the firewall...
Besides cleaning up flametrap, inspecting that plug, and replacing valve cover gasket, I would suggest using Pennzoil® High Mileage oil, which has Active Cleansing Agents for sludge removal.
- 93Regina
TROUBLEvcowens wrote:What is that plugs function and name.
It's cheaper at the dealership: item 41
Manufacturer Part Number: 1336763
Volvo 240 244 245 Rear Cylinder Head Plug
- 724 Views
Last post by Ozark Lee
- 13 Replies
- 4430 Views
Last post by erikv11
- 1494 Views
Last post by callahanoffroad
- 1031 Views
Last post by smeha
- 2667 Views
Last post by jblackburn
