1998 V70XC AWD Timing Belt + Water Pump Replacement
Carboncopy
Year and Model: 1994 Volvo 850 GLE
Post by Carboncopy »
Hi Guys,
I am hoping to change out my V70 XC's timing belt, rollers and water pump in the next few days. My car has the automatic adjustment system and I had a few questions before taking everything apart. I have read over a few tutorials on how to do this and I have the haynes manual, but I was wondering if there was any additional advice anyone could give a newbie to maybe make this process easier, as this is my first time ever replacing this stuff (I am relatively mechanically inclined, but not super experienced :lol: ). My second question is can anyone provide a breakdown of how to reuse and re-compress the hydraulic tensioner? I have not really found a great explanation on how exactly this is done.
Any help or advice anyone can give would be greatly appreciated! This forum has been a great source of information :D
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
See:
https://www.matthewsvolvosite.com/forums ... hp?t=53722
PS: Hydraulic tensioner, compress very slowly with a vise or wood-working pipe clamp (this is what I use b/c I own some wood-working tools).
Below is a sample photo of wood-working pipe clamp:
Post by cn90 »
I forgot to mention that it takes about 5-7 min to compress the HT.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
...when you fully compress it,check for leaks at it and if there are no leaks,insert a piece of steel wire on it's opening to lock it.When you allign everything and when time comes....just pull the "granade pin",triple re-check your timing marks before and after you fully turn the crankcase manually for whole 3 revolutions before starting engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Volvo Timing Belt Replacement, S70, 850, V70 (Par…:
rspi
Post by rspi »
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
Just a clarification: are we just testing the integrity of the H.T. before we re use it to see if it is leaking? Or does it have to be re-compressed to be reinstalled?
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
The latter. It must be re-compressed to be re-installed, so check it for leaks at that time.
Carboncopy
Thanks for the information and the videos, fingers crossed my tensioner is not leaking.
Carboncopy
Hi all,
Another quick question before I start this job, if a cam gear happens to fall out of alignment when I have the belt off, is it aright to simply turn it back to the mark?
