2001 xc70 radiator fan doesn't cycle
Danpaco
Year and Model: 01 xc70
Post by Danpaco »
I finally got my new to me ride on the road after an epic struggle with the DMV. The car has been parked in my driveway for two weeks and the weather has been cold and snowy.
When I started the car today I noticed the radiator fan was on high and would not cycle to off. The AC is off in the cabin as is the windshield defroster. Any thoughts as to why this is? And where can I start diagnosing this problem?
The fan behaved normally on my test drive and engine compartment inspection three weeks ago.
Thanks
Danpaco
jimmy57
Been thanked: 322 times
Post by jimmy57 »
If the ect sensor (engine coolant temp) is unplugged, wires broken, mice chewed through wires, etc. then the ECM will run fan at high with key on.
Danpaco
Post by Danpaco »
Where could I find the ECT?
Danpaco
Post by Danpaco »
Everything looks good with the ECT wires and connection. Before I start throwing parts at the problem, thermostat,new sensor, etc..., what can I test electrically? What should the resistance value be on the ECT, is there a relay control I can check?
The car runs well, no CEL, no hidden codes, just passed emissions.
I do notice the temp gauge in the cabin is slightly past "12 oclock".
Any help would be appreciated.
Danpaco
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Danpaco wrote: ...
I do notice the temp gauge in the cabin is slightly past "12 o'clock".
I had same issue; temp needle taking longer to reach 12 and then visibly staying pass 12.
The engine hood over the passenger section will smell hot, and high-temp at touch. The protective cover over the spark plug extremely hot. But the car ran fine.
Changed thermostat around 134,000 miles with Wahler/Volvo. It was original.
I have serviced and replaced all heating and cooling parts in past 18 months, except radiator.
