2006 C70 P0340 & P0365
theguyoverhere
Year and Model: 2003
Post by theguyoverhere »
I start the car it fires right up, then I shut it off and it just cranks, sometimes it will start eventually, igf I clear the code it fires right up again with a pending p0340 and p0365 which goes current when I try to restart
I checked the timing by taking the crank pulley off and checking the mark down on the crank gear and the oil pump housing and the two marks on the crankshaft and cover, spot on, I even put on a new belt and tensioner
is there some wiring I should check? could this be caused by the cam adjust solenoids?
some help would be greatly appreciated
thank you
theguyoverhere
does anyone know where I can find a wiring diagram so I can test the wiring?
thank you
(also any other suggestions?)
