Hello, I encounter a problem when I order original parts.
Some parts in VIDA is marked strictly compatible with motor number to which this part fits.
Where to find engine number?
example:
30620676 Camshaft Engine No. to 8467
30621267 Camshaft Engine No. from 8468
30883834 Pulley Engine No. to 19167
31303117 Pulley Engine No. from 19168-39861
It is not chassis number, because it is written as CH -715099.
I found only this at the cylinder block, is it is or not:
F9QD14192T3
C049781
Where is the engine number?
precopster
- Year and Model: Lots
- Been thanked: 128 times
On white block motors the engine number faces up toward the sky and is situated on a plate near cylinder 1 exhaust port. It is not easy to find.
reGSPlmNjn
- Year and Model: V40 2002 1.9D
I finally got an answer to my question,precopster wrote:On white block motors the engine number faces up toward the sky and is situated on a plate near cylinder 1 exhaust port. It is not easy to find.
At V40/S40 1.9TDI the Engine Number is located to the right of the oil filter, at the cylinder block, as pictured.
All you need when you order the original parts, to write these numbers after "C" letter: C049781
Example:
30620676 Camshaft Engine No. to 8467 (for engines before 008467)
30621267 Camshaft Engine No. from 8468 (for engines after 008467)
This mean that if my engine number 049781, my parts is 30621267 (for engines after 008467).
precopster
Apologies using Tapatalk doesn't display full profile details such as vehicle so I assumed a petrol engine. Glad you found it.
- 493 Views
Last post by erikv11
- 845 Views
Last post by Ozark Lee
- 1342 Views
Last post by caj767314922
- 5597 Views
Last post by precopster
- 1228 Views
Last post by theWaterBiscuit
