1995 850 lost only key. need to start car without key plz
I lost my only key to my 1995 850 volvo. called the dealership and a locksmith way to expensive for a mom of three. Not worried about what it will look like jist really need to start my car without a key. Should I drill the ignition switch? take out cylinder? I really need advice plz.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I'm affraid that a very good locksmith or a dealer are your only options.
Other than that you can buy used ignition switch with a key from junkyard and have somebody to install it for you.
Other than that,your last option is to install a starting switch like on newer bmw.But it costs also.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Who knows how much they asked for it.
They are "stealership",remember.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
I can't give you advice how to drill it,but locksmiths know how to do that.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
Look at the post from cn90 up above, if you use the little "PM" button there to contact him, he may be able to help you get a key for a lot less money.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
A dealer should be able to cut one with proof of ownership and your VIN.
More than likely mail it out to you as well, so shop around.
The spares should be pretty cheap after that.
- Been thanked: 504 times
Contact a few dealers within 200 miles from your place.
Fax them your proof of ownership (driver license, registration) and your VIN number.
They will make the keys for you ($7/each).
Part Number is 9447946. See the link below for an example of pricing and application:
http://www.volvopartswebstore.com/produ ... 47946.html
PS: If you are desperate, then search forum for removal of electrical portion of the switch (left side of steering column) and use a screwdriver to start the engine. You need to prove to yourself (your driver license and vehicle registration) that you are the owner before doing this.
- 16 Replies
- 5595 Views
Last post by MrAl
- 2100 Views
Last post by RickHaleParker
- 1582 Views
- 1993 Views
Last post by PeteB
- 872 Views
Last post by BlackBart
