95 940 front wheel bearing hub
greekbuckeye
Year and Model: 1999 S80 2.9
Post by greekbuckeye »
Hey y'all,
Just took my 95 940 to the shop for a groupon oil change, brake check, tire rotation, and they said the front bearings need replaced because they are loose and it has caused uneven tire wear. How challenging is this at home? Are they press fit, because if so I heard you have to have a press for that which I do not have. Thanks in advance.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
greekbuckeye wrote:front bearings need replaced because they are loose and it has caused uneven tire wear.
I would suspect its a hub-assembly, which means whole unit is replaced.
I would be checking for looseness in tie-rod ends, bottom ball-Joint, and that strut-rod bushings. Those strut-rod bushings do fail. I suspect its not a wheel bearing issue, but these items I mentioned.
Volvo Maintenance FAQ for 7xx/9xx/90 Cars
greekbuckeye
Thanks!
