Any input on how to solve this issue would be much appreciated!!
1998 Volvo S70 Map sensor / Accelerator sensor
I have a 1998 Volvo s70, It gave me a check engine light for the acceleration sensor and the MAP sensor.....First I changed the acceleration sensor , the code for the acceleration sensor was gone...I still have the MAP sensor code, Changed the MAP sensor and Got both codes back (for acceleration sensor and map sensor
.....I also changed low and High ac pressure as I know that they all share the same Ground, Still have the check engine light codes for both MAP and Acceleration sensor...
- Year and Model: Many Volvos
- Been thanked: 76 times
Exactly what code numbers are you getting? In many cases the Volvo P codes can register as something else on the scanners that try to identify the problem for you.
