I was turning around in a parking lot and my steering pump went,,,, loudly. Which was funny because I was in the mall parking lot and a lot of heads turned when it started to make a real loud wwwiiiirrrrrrrr sound while I was turning my wheels tiring to figure out if it was my car or not I think it was the fourth turn and say good by.... No more power steering and the pump is making a lot of noise while the car is idling. Is this bad for the belt?
Looking for a good write-up. I am going to change the belt too is there anything else I should add to the list???
1995 850 Had power steering till I did not....
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Are you sure the pump is boned? I'd add fluid and see if it stays in there and makes the sound go away. I'd also not run the engine until I got some juice in there. Probably not good to have the pump running unlubricated.
Cracked reservoirs are not uncommon, and I had a hose mysteriously come loose once. Best to avoid inflicting damage before you know that damage has already been done.
Yes your half right I filled it up to high full (3 Ounces) of steering fluid drove a around 4 miles and checked it it had gone down a bit. 2 hours later there is a puddle in the drive way and the fluid is just missing the bottom of the low line. The steering still had a sound half as loud as before (no where close as silent as it was) but still loud when it was filled I'm guessing this hole or what ever must be large to loss fluid that fast.
j-dawg
Can you see a trail of fluid on the hoses or in the engine bay? Perhaps you can find where it's leaking from and correct it.
def. see if it is leaking on the rack or at the hose/reserv. Some swear by lucas power steering leak stop but I have never used it.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
'97 855 N/A
Just bad luck longer tube that goes into the steering has a leak around the bolt the tube may have rusted right through. The short one looks even worse. Does anyone know the part numbers for these 2 Tubes I have no idea what they are called. Oh (side thought) does anyone know where the steering rack part number is? I was looking for it and did not see it.
http://www.partsforvolvosonline.com/
Killer parts site) it took f-ingggg forever but the local dealership called back, wants 300+ dollars for the 2 pipes I needed this site has the steering column MAP!!!! Does any one remember when Eeuro didn't suck?? Found the 2 pipes I need for under 80 check these guys out next time you can't find something at a junk yard.
- 1124 Views
Last post by James_A_Sousa
- 1291 Views
Last post by sweetwheel
- 1991 Views
Last post by alschnertz
- 1214 Views
Last post by ggleavitt
- 1867 Views
