1998 S70 T5 - hard cold start
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
Hi all - way up here in the great white north winter is hitting us hard. It also appears to be hitting my S70 hard as well. She does not appear to like starting when the temp is below about -15ºC. I started using the (OE?) block heater which makes a big difference but this morning (-25ºC) she turned over, fired right away and then promptly shut down. After this despite numerous crank attempts she would not start again. When this has happened in the past waiting for the temp to warm up a bit always seems to fix it ... any thoughts? BTW, I do all my own maintenance and just replaced the cam seal at the distributor back in the fall that was giving a no start due to bad spark. Battery is good and still provides lot of power to crank. Fuel shouldn't be a problem as she will start and run fine when it warms up a bit.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- Year and Model: Many Volvos
- Been thanked: 76 times
There are a couple of "usual suspects" for hard starting. The most common is a bad ECT sensor. A non OEM sensor that is otherwise good can have similar problems. Beyond that a bad check valve in the fuel pump can cause starting trouble but that typically isn't ambient temperature related.
shegarty
Thanks Lee -
- from what I understand this would usually throw a code and light up the lamba light would it not? I have had some problems with the EVAP that I am planning on tracking down in the spring but I have never had a code for the ECT. Is it possible that a bad or faulty ECT could account for the ambient temperature condition that I am getting now?Ozark Lee wrote:The most common is a bad ECT sensor
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
It may be possible that your ect is marginal and does not trigger code. Ect reads a high resistance when cold, in the range of 1600 ohms. Say yours only reads 1000 ohms, then ecu thinks engine is part warm and supplies less fuel. Easy enough to check by removing a plug, if soaked in fuel chances are ect works. In this cold though, gut feeling goes more towards electrics. So if you pull that plug check for spark as well.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
shegarty
Ok, so a small update looking for some ideas ... this morning in about -22ºC with the (OEM?) block heater plugged in for about 3hrs she turned over, fired immediately and ran for about 3 secs before promptly cutting out as if fuel was cut off. Further attempts resulted in the car turning over (starter engaging, engine cranking) but no ignition. As I was on my way out to work I didn't have any time to diagnose or troubleshoot. I am going to try when I get home but most likely it will be warm enough again for it to start without a problem. My thoughts are now leaning towards something electrical
and will maybe start with the fuel pump relay as I can easily jumper it or replace it with a spare unit. Any other thoughts???draser wrote: In this cold though, gut feeling goes more towards electrics
As fuel pump relays die they tend to get temperature dependent and it can work both ways - hot to cold and cold to hot but usually the latter. It is easy enough to bypass it and see.
shegarty
of course that would depend on the weather cooperatingOzark Lee wrote:It is easy enough to bypass it and see.
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
The rpm/crank sensor will shut the engine off if it stops sending a signal. It could be a marginal connection that gets jostled a little after startup when things are vibrating. Things expand when they warm up!
JeffHicks
- Year and Model: 1989 240 Wagon,
I had this exact same problem with my 99 V70. Any time it was below Zero (F) the thing would do exactly as you described - kinda fire, then immediately die and refuse to start again.shegarty wrote:Hi all - way up here in the great white north winter is hitting us hard. It also appears to be hitting my S70 hard as well. She does not appear to like starting when the temp is below about -15ºC. I started using the (OE?) block heater which makes a big difference but this morning (-25ºC) she turned over, fired right away and then promptly shut down. After this despite numerous crank attempts she would not start again. When this has happened in the past waiting for the temp to warm up a bit always seems to fix it ... any thoughts? BTW, I do all my own maintenance and just replaced the cam seal at the distributor back in the fall that was giving a no start due to bad spark. Battery is good and still provides lot of power to crank. Fuel shouldn't be a problem as she will start and run fine when it warms up a bit.
My problem ended up being a fuel pump relay that was worn to the point where (apparently) it really hated the cold. I replaced the relay, and no more problems.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
shegarty
Just when I thought Mother Nature was going to give me a short reprieve with some warmer weather ... now she was refusing to start today in only -2ºC
So here's the latest:
***Pretty sure its not the fuel pump relay as I switched it out and no change - I can also hear the pump priming
***Checked for spark - decent from the coil (even tried different known good coil) - pulled cap to check cam seal as this was done not too long ago - all checks out good - haven't checked an individual plug yet as unlikely to be bad and its cold and dark here now
***After I finally got it started today (repeated turning over) tried unplugging the MAF (when engine cold) and she cleared up a bit. Upon plugging the MAF back in again she promptly stalled and when I checked she had thrown a P0102 code (not sure if that happened before or after plugging it back in)
***If you read further up this condition happened before when it was much colder without touching the MAF - she would turn over, fire and run for about 2-3 secs and then promptly stall out and then refuse to restart
***Replaced the MAF with known good one - no change, following the same procedure with replacement causes the same code - Before messing with all of this the MAF that she started the day with was BOSCH OEM and replaced by PO just over a year ago
***Once warm she will start up again no problem
I'm pulling my hair out on this one. To me it feels like some sort of metering problem. The previous mention of the ECT is I suppose my last resort but I am reluctant to replace it now that the source of the problem seems to have changed (previously only a no start in colder temps, less than -17ºC). Any thoughts ...
- 1440 Views
Last post by renegade343
- 25 Replies
- 4240 Views
Last post by 800artfreed
- 1340 Views
Last post by schnellcgw
- 1127 Views
Last post by oragex
- 844 Views
Last post by misha
