2006 s60 help removing fuel line from rail
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
I am doing my breather box.. The connection of the rail and fuel line is a little different then what i am use to. It is the newer version of the connection. black with a torx screw which I removed and the lock casing by lifting the tab. Now I want to disconnect the line but can't figure out how. Will it lift out when I pull the intake up?
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
you have to unscrew all the bolts and pull the injectors out first, the line will have some play to allow you to do that then you will have better view what's there it should have a clip you press to pull it apart
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
