2001 xc awd turbo radiator repalcement
tcmotoringmechanic
- Year and Model: 2000 volvo v70
i need help. i have every thing out for the radiator to come out . But its still hung in there any tips. this is my third Volvo of my career. it is also turbo charged
not sure what you have already taken apart but the radiator is secured by few bolts first is 2 on header panel then 2 long ones on each side of the radiator which unscrew from underneath then there is 4 bolts that secure radiator, intercooler, a/c condenser together best way is to take all of it off as an assembly but will have to drain your a/c refrigerant
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
I did this job on an 02 v70XC. I remembered that my radiator came out through the top. I think its easier to get the intercooler and radiator out together through bottom. If you are working by yourself then I'd say you need to sandwich the intercooler and radiator before putting them back on through the bottom. Not sure if you have to remove the front bumper but I did because I installed the external ATF cooler during that job.
Check your PCV system too. You would save time replacing it with this job.
- SuperHerman
- Been thanked: 207 times
It comes out the bottom. I just did mine and it was not easy. It hangs up on everything and then some more. Follow all the unhooks and then get an extra pair of hands in there to move the harnesses and hoses that find their way back to being in the way. The funny plastic mounting pieces get stuck on various hoses - if I recall the tranny lines and air cooler. Just get it all out of the way. It also has some tilt left then right or right and then left action as you lift it.
DO NOT TWIST THE NEW UNIT!!! This is the cause of premature failure. Put it in but do not force it.
- 267 Views
Last post by tcmotoringmechanic
- 1485 Views
Last post by techedbob
- 3549 Views
Last post by t3yf5g
- 7125 Views
Last post by jalwlb
- 100 Views
Last post by volvolugnut
