1993 850. ECC fan resistor bypass.
Willis-Bass
Year and Model: 850. 1993
Post by Willis-Bass »
Has anybody done a temp by pass of the heater fan resistor on an early ECC car? Is it feasible by directly powering fan? I don't care if if only runs on high speed as I plan to sell the car in the next few weeks. I have replaced the resistor once with a used one and got about nine months out of it. It is too cold to go to the junk yard and I do not want to invest in a new resistor.
humbertoflores63
Year and Model: 1995, 97, 98
Has thanked: 1 time
Post by humbertoflores63 »
I did it for a winter until I found a used controller. The relay only controls the amount of ground, by changing this the blower speed is control. I made a jumper with a on/off switch that I manually turn on or off has needed. I also found to never, ever used the auto setting it burned 2 ECC's before I discover this!
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
If you've had two motor controllers fail, may have a failing blower motor.
But if you're planning to sell, bypassing the controller and grounding the
motor through a switch is certainly a quick and dirty option.
As for the AUTO mode killing other components? I doubt it.
If there was some kind of issue, it would be all over the boards.
It's much more likely that your '98's ECC had some other problem.
humbertoflores63
Has thanked: 1 time
Since I stop using the auto mode, the controller is been working fine for 4 years.
The blower motor was almost new when the controllers gave me the ghost!
BEJinFbk
Post by BEJinFbk »
I'm gonna go out on a limb and guess
that those were both used controllers?
