03 XC90 DIM swap issues
jaces_dad
- Year and Model: 2001 V70 XC70
Hi all, I've been having issues with my instrument cluster going dead on me so i finally bit the bullet and replaced it. I got one from my local salvage yard, these cars are very hard to find in the bone yard around here, by the way. So the one i got came out of a 2004. I've read a few different opinions n whether or not it would work in my car and i figured if the gauges work finally I'm ahead of the game, i'm not worried about the other issues. Everything works but with the following issues.... My car has 239,000 miles on it and the car the DIM came from only had 167,000 and the odometer shows the 167k. I read on here that if my car has more mileage than the one the dim comes from it will take the mileage from my car. Just a heads up, that's not the case. Also the air bag warning and orange ! are still there and now i have the alarm service message too. Any thoughts?
Try disconnecting your battery for the alarm system, as for the airbag warning light there can be too many issues ( even the speedometer it self) so for that you will need a Volvo scanner to pin point the problem.
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
If DIM is faulty Airbag message will come up. Needs to be cleaned with scanner.
Alarm service is for siren module. Usually means acid from battery (inside siren module) is leaked.
If you have questions about Volvo firmware ask me. I may know an answer
jaces_dad
Thanks for the suggestions, I did disconnect the battery for about an hour and nothing changed. Also the alarm message came up when the original DIM went on the fritz. I have a local shop here in town that specializes in Volvo and is way less expensive than the dealer so I may have them have a look at it for me.
- 4115 Views
Last post by Antherzoll
- 1496 Views
Last post by Hnizdo
- 424 Views
- 2347 Views
Last post by doublebug
- 397 Views
Last post by EDT
