1994 850 fuel injector spacer rings Part #: 3528216
petek153
- Year and Model: 1992 940T
So after battling the cold for the past month here in Ct. (been working outside ) finally got the head gasket done and car back together and running. After moving the car found a seal on the ground and then a second after research found that they are upper fuel rail spacer rings. Never saw them fall out but must of when I removed injectors only found 2 of the five I assume they all had them. I've had the injectors out on my 95,96,97 850's and they don't have these seals but evidently the 94 does car is running with no leaks and want to know if I should order up a set and install or did they decide in later years that these aren't needed ? What's your thoughts?
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
northernlights
- Year and Model: 850 Turbo 1994
- Location: Florida and/or Raleigh NC, depending on the day
- Been thanked: 8 times
My 94 has them, and I replaced them, plus the seals, when I had the injectors out. Who knows how important they are or if they can wear out, but I hate to not put things back the way that they were.
I used the cheaper Victor Reinz ones that FCP lists for $1.59 each.
- 3135 Views
Last post by 93Regina
- 1332 Views
- 14 Replies
- 1559 Views
Last post by rguzz
- 1951 Views
Last post by erikv11
- 637 Views
Last post by BlackThunder
