Hi,
My power-operated tailgate close button recently stopped working. In addition, in the same timeframe, I replaced my rear dome light only to have it burn out two weeks later. In addition, I've been receiving the "rear position lamp failure" warning every once in a while but no lights are out (except for the dome light!).
Volvo has diagnosed this as a faulty POT module and has suggested a full replacement and software download for a whopping $900!
Having fiddled with my V40's CEM to correct the common headlight relay issue, I'm tempted to determine whether or not one or more components on the POT module could be replaced to fix the issue at a more reasonable cost. Has anyone here experimented with their POT module? For that matter, has anyone had similar issues with a cheaper resolution?
2010 V70 New Power Operated Tailgate Module required
- pierremcalpine
- Year and Model: V40 2003, V70 2010
- Has thanked: 2 times
- Been thanked: 5 times
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There are tail light bulbs on the tailgate(position lamps), dome light for cargo area, and POT switch all in the wiring harness from tailgate to body.
Broken wires they could explain all your issues.
I assume the tailgate will raise with no problem with dash switch, remote, or by opening tailgate manually
- pierremcalpine
Thanks, Jimmy. I will check that next...once the weather warms up, that is. Yes, you are correct. Everything else is working as expected (dash button, auto-open with latch, remote, etc).jimmy57 wrote:There are tail light bulbs on the tailgate(position lamps), dome light for cargo area, and POT switch all in the wiring harness from tailgate to body.
- 2363 Views
Last post by von brutus
- 4590 Views
- 1442 Views
Last post by dennisallum
- 15 Replies
- 11007 Views
Last post by aaronlife
- 837 Views
