Hi Volvorinos,
The Green/Red wire that goes from the ignition switch to the starter solenoid (to activate it) has 50 volts according to electrical diagrams. I need to know how many amps that wire draws. Can't seem to find the information anywhere and I don't have an amp meter.
Why I need to know:
I want to install a hidden push switch along the wire, so that the car will only start if you're pressing the hidden button at the same time you turn the key (i.e. cut the wire and place button in between). I need to know the amperage so I can get a button that will be able to handle the load.
Thanks in advance
1994 volvo 855 - solenoid amp draw
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I haven't measured it, but I'd guess that a pushhbutton switch that can handle 10A should be OK for the short duty cycles needed on a starter solenoid.
There are descriptions in the links below suggesting a typical 5-10A current draw for the solenoid:
http://webcache.googleusercontent.com/s ... clnk&gl=us
http://forum.allaboutcircuits.com/threa ... ids.69799/
- Year and Model: Many Volvos
- Been thanked: 76 times
I'm not sure where 50 volts came from. The starter solenoid activates with battery voltage which is 13ish volts. There isn't all that much current either but a 5 to 10 amp rated switch should work forever.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
That starter solenoid terminal is DIN terminal 50. DIN 30 is battery + constant, 15 is switched 12v +, 31 is ground.
Starter solenoid is 6-8A initially due to both windings being energized in the first fraction of a second but only 3-4 amps for hold-in winding for the rest of the period starter is engaged.
Quick follow-up: Installed the 7,5 amp push-button. Works perfectly. My car always starts in less than half a second so it's no problem. Was wondering what would happen one day when it doesn't start so easily, and if button would melt from the heat or something, but jimmy57 has just answered that nicely (Thanks!). Since the amps drop after initial contact, should not be a problem. (if it does ever happen, I'll come back here and post the results)
I'm very happy with my new little security mod. (won't post photos because that would defeat the purpose of a hidden button).
A little humour: It also crossed my mind that one day I might be out for a few drinks with friends, and i'll forget about the button and won't e able to start car
... Now my little mod also prevents me from drunk driving. What a cool little 2in1.
Thanks to everyone for your help.
1994 Volvo 855 GLT - 2.5, 20 valves, non-turbo. My first Volvo. What a dream. This car practically drives itself.
jimmy57
The only time your switch is at risk would be if the battery is weak and you keep trying to get starter to engage. That is when the high amp phase could last more than 2-4 milliseconds.
I'm not sure your button rises to the level of being an alcolock though......
- 738 Views
Last post by walczyk
- 3050 Views
Last post by Cees Klumper
- 2032 Views
Last post by pb49415
- 11 Replies
- 2668 Views
Last post by mecheng
- 1885 Views
Last post by MoVolvos
