My T5 5 speed.. has a hesitation. I can rev up to red line in first gear shift to second and im getting a very noticeable hesitation with the throttle wide open. Its not bad if i hold the pedal down about half way and let it rev up.
Ive tried new coil packs, it has new plugs, i removed the ETM and cleaned it and swapped the CVVT solenoid with a known good one. The ETM and CVVT solenoid showed codes is why i tried swapping/cleaning. I also checked the fuel pressure running and idling and its staying about 55psi.
Currently no codes are coming up anymore but still has hesitation. Any ideas ??
2001 Volvo S60T5 Hesitation
- phils94850
- Year and Model: 2009 s60 turbo
1996 Platinum Edition
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Turbo Control Valve?
- phils94850
It showed a P1171 code which ive researched is usually the MAF. Luckily my wife drives the exact same car so i can "borrow" hers and see if that fixes it.
- phils94850
Took the MAF off the wifes car and that fixed it.. so ordering a new MAF
- 1212 Views
Last post by fields 100
- 422 Views
Last post by Bill1959
- 273 Views
Last post by foggydogg
- 541 Views
Last post by azureblue
- 373 Views
