I have to remove my DIM for repair, it will take several days to have it back.
With the DIM removed, door locks and windows don't operate. This is extremely annoying as I drive trough gates where I MUST lower the window to communicate with people.
I have gone through all the pages of the Wiring Diagram but still can't figure out which of the 14 pins on the DIM connector power the door locks switch or at least the driver window.
Can anybody shed light into this.
Many thanks
2002 S60 Driving with DIM removed advice needed
doublebug
- Year and Model: XC90 2007 D5
- Been thanked: 7 times
You need to restore CAN bus.
On the connector look at 2 twisted pair (green with white)
You need to short white with white and green with green.
contact numbers on the DIMs connector
9 with 3
8 with 2.
When you install DIM you will need to clear error codes with some scanner that supports SRS.
9 with 3
8 with 2.
If you have questions about Volvo firmware ask me. I may know an answer
It worked.
Thank you again.
Now, keeping the pins shorted all the time should not cause any nattery drainage right?
With so many complex circuitry one never knows ?
It worked.
Thank you again.
S60 2002 180K miles looks and runs like new (except when sulking)
- 999 Views
Last post by vtl
- 1340 Views
Last post by Botbasher
- 587 Views
Last post by vtl
- 14 Replies
- 1294 Views
Last post by RickHaleParker
- 1427 Views
Last post by chrism
