2002 XC70 Fan Squeak
Stephen0523
Year and Model: XC70 2002
Post by Stephen0523 »
Hello.
Recently my 2002 XC 70 has been squeaking when the fan is on low first or second light.
The squeaking sound seems to be coming from the passenger side.
Would anyone know how I can get in there to apply some lubrication?
Thanks in advance
Stephen
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
really hard to lubricate even after removing it from near the passenger feet, because the upper bearing is causing the noise and it's not accessible
better replace the fan with used one off Ebay (you can keep the resistor)- look at the pictures for the pin in the middle of the blades- if it's rusted, chances are it will squeak too in cold weather.
Stephen0523
Thanks Oragex for the fast reply, were there supposed to be any photos attached? If not please send and also any tips on removing the fan.
oragex
Post by oragex »
This is a great How-to with pics. Notice the pin in the middle of the blower, looks clean - well, that was a new one
An angled screw driver is of great use because 2 screws are really hard to reach
https://www.matthewsvolvosite.com/forums ... =9&t=21343
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I would not go with a used fan - the lube grease will be old and crusty and destined to make noise sooner than later. You can take the motor apart and grease the two bearings on each end. You have to remove the squirrel cage fan, which is not easy as it is a press fit. It will come off slowly and takes some time and effort. You need to take the fan off and then the entire motor out of the plastic assembly - then you will see the bearings on each end - then open up the motor, clean the old crud and relube with some quality grease.
I bought a new non-OEM fan assembly and took the old one apart to see what failed - this is how I learned the grease was old and basically no longer there. Now I have a spare sitting for the next fan that goes.
The cheap route, under $50, if you do not want to rebuild is to buy a non-OEM motor/fan with plastics and replace the assembly using what is needed from the old unit - like the electronics.
