Hello, the front passanger door dome light switch is not always working causing some lights to stay on, it has killed the battery more than once. I assume that the switch is behind the door panel by the latch (?) Is this true, if so, how do I get to it to replace it? Any suggestions will be appreciated.
Thank you
CO
1999 S70AWD passanger side door light switch
- Year and Model: Many Volvos
- Been thanked: 76 times
Unfortunately the switch is built into the latch assembly and I have not been able to source just the switch portion of the latch to solder in a replacement. I was able to make a thin plastic shim that I glued in to force the switch to be depressed a fuzz more and that solved my problem when the same thing happened to my S70.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
- Has thanked: 2207 times
Expect to break some of the plastic retainers when you remove the panel. So either stock up with some from the dealer or go to a Pick-n-pull and practice removing a few door panels and removing the clips that don't break.
The chances of not breaking the clips and having the mounts not come unglued approaches zero. I have used a hot glue gun to re-secure the mounts on the panels.
...Lee, Neil and Robert, thank you all for your help, it is incredible how much easier a task becomes when getting relevant information. I will not be able to get back to this repair until Monday or Tuesday.. I will let you know how it turns out.
CO
CO
- 956 Views
Last post by chefmarkt69
- 459 Views
- 512 Views
Last post by cn90
- 63 Replies
- 16287 Views
Last post by JCT5
- 5753 Views
