1999 S70 T5 - What is normal fuel pressure?
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Hi all,
I measured the fuel pressure on my T5 the other day. LTFT is off the roof. These are the values I got:
* Key in position II (car not running) 40 psi
* Idle 56psi
* Revving engine when in Park 56psi
* 40psi after engine is shut off
* 10 min after shut off 36psi
* 20 min after shut off 32psi
Can someone tell me if these values are considered to be ok?
BMW 540i 2002
S70 Base 2000
JDS60R
Been thanked: 3 times
Post by JDS60R »
380 kilopascals =
55.1143403 pounds per square inch
99 s70 T5 fuel pressure.pdf
(62.97 KiB) Downloaded 643 times
Retired
kallekula
Post by kallekula »
JDS60R wrote:380 kilopascals =
Thanks. Gotta get me Vida.
BMW 540i 2002
S70 Base 2000
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Sound ok to me.
Any codes?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
s70fanman
Year and Model: 1998 s70 t5
Post by s70fanman »
Gentlemen-
The CHILTON Manual says that T5 HPT Fuel Pressure is 58 lbs. per inch. Mine has trouble reaching that but is constant at 50. Good Luck
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Of course pressure drops when engine isn't running because pump is off.
Pressures will drop with time; this is also normal.
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
And LTFT is positive or negative?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
kallekula
Post by kallekula »
Its running lean.
BMW 540i 2002
S70 Base 2000
Has thanked: 2203 times
Been thanked: 1852 times
Volvo info from my local dealer foreman says fuel pressure should be above 3 bar (approx. 43psi). The dealer measured my 2000 V70R at 4 bar (around 60psi).
draser
Post by draser »
If it's running lean, i.e. fuel trims are positive, you'd be rather interested in air leaks. Plug in scanner with engine warm, watch STFT and rev engine to 3k steady. If trim goes closer to zero you have air leaks.
