Did some searching around and there didn't seem to be a definite answer on whether or not you needed the extra wiring harness for the 02 front and rears sensors on my volvo 850 normally aspirated car? Whats the reason?
thoughts?
thanks!
1997 volvo 850 yes or no? the extra 02 sensor wiring harness
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Bosch 0 258 005 097 front o2
Bosch 0 258 005 062 rear o2
Those are oem Bosch o2 sensors and they are direct fit.No need for extra wiring.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
camjohns
- Year and Model: N/A 850 97, 850R 96
- Has thanked: 6 times
according to FCP if i have a 1997 volvo 850 that i need to purchase an extra wire harness to purchase.
links:
rear:
https://www.fcpeuro.com/products/volvo- ... -v70-15062
front:
https://www.fcpeuro.com/products/volvo- ... -v70-15097
extra harness
front
https://www.fcpeuro.com/products/volvo- ... nt-9202714
rear:
https://www.fcpeuro.com/products/volvo- ... ar-9202715
just got a little confused if that was something i needed
thanks!
links:
rear:
front:
extra harness
front
rear:
thanks!
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
I believe that extra harness length was for moving the plug to a better place to avoid water or dirt ingress. It came with my front sensor, but I never used it.
From IPD`s website.
Product Description
Some 1996 & 1997 850 models may require extra length for oxygen sensor. Volvo changed second sensor location to after the catalyst to prevent contamination of the sensor.
From IPD`s website.
Product Description
- misha
I also have a '97.
You don't need extra harness.O2 sensors are all you need.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
camjohns
Ok, but as i was looking at the pictures for the 02 sensor (from the link above), I'm wondering if that connection is the correct one?
When looking at the wiring harness (also from the link above), it has a different connection (with a red piece in it)
- misha
Those connectors with"red piece" in it are just extensions.
You have "red piece" connectors under the hood and your o2 sensors are allready connected to them.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Hey Misha,misha wrote: 09 Mar 2015, 02:01 Bosch 0 258 005 097 front o2
Thank you for your help all these years.
My 97 850 N/A runs great. Are these O2 sensor number still true for ordering? I will go with NO harness.
- 14 Replies
- 4611 Views
Last post by CIK7
- 5571 Views
Last post by gnalan
- 864 Views
Last post by wapitiscat
- 2062 Views
Last post by mrbrian200
- 11902 Views
