Hi all,
Just purchased a 2002 V70 N/A with an etm problem,replaced the etm with a xemodex etm the car ran great for about 2 weeks then on cold start limp mode poor ldle and OBD2 code P1026. let the car warm up a bit and was able to reset. now it seems to be getting more frequent.thought bad grounding cleaned and performed etm flow chart test but can't seem to find anything wrong. could this be the MAF acting up ?
road runner
- Year and Model: 2000 xc70 99 v70 98
road runner
up date,
since cleaning ground for etm and removing relay and putting it back I've had no problem ? the ground was clean but maybe not grounding good or the relay wasn't making good contact. maybe it didn't need the ETM ?
precopster
- Year and Model: Lots
- Been thanked: 128 times
ETM is always on the short blame list even when symptoms and codes don't point to it.
Were the codes P1026 prior to ETM replacement?
road runner
yes
precopster
Error code P1026 on a Volvo is usually a transmission code related to speed sensors of which there are two.
Best thing is to scan this car with a Vida/Dice system
road runner
a little more insight, It seems to do it when the temprature drops fast ?
yesterday it was +3 C and drops to -6 C in about 4hrs and when I started it it was in limp mode. could it be moisture in the ECM that freezes ? after it warms up to operating temp turn it off and restart and it's out of limp. the code P1026 will remain for 3-4 starts and clear. it also gives P2077 witch is the o2 that I figure is from the way it's sputtering
precopster
I would call XeModex and get their opinion; after all you have the code reading and they know best how to decipher the P codes you're getting.
If they still believe it's a throttle issue they'll replace it. P1026 doesn't translate to any code in Volvo nomenclature using the Equus site.
Best to have it read by a Volvo specific scanner such as an Autel EU-702, 801 or 802 or a Vida/Dice setup.
road runner
so I purchased a vida dice not so good with it yet but am getting fault ECM-914F throttle position (TP) sensor 1 and 2 faulty signal,I performed the etm test and there was only a diff of 1.27 deg. I also have a fault with the siren for the alarm UEM-0004 communication fault. could this cause a problem? this car also has a remote starter that is in valet mode could this part of the problem ? When it goes into limp if I pull/replace the fuse the etm gives me a double click (on then off ?)and changes nothing I also tried replacing the relay with no change but if I unplug the ETM and plug it back in it resets the ETM and I'm back on my way for maybe 10 min. or 2 days. thanks in advance
precopster
Looks more and more like a faulty ETM; pretty rare for a XeModex to fail but is possible of course. The double click is the self diagnostic function telling you it has totally lost input from one of the sensors. 914F is usually an internal permanent fault.
road runner
I called Xemodex and spoke with tech support and they sent me another ETM .I replaced it and all problems are gone. Thanks everyone for your help
- 4757 Views
Last post by firstv70volvo
- 5022 Views
Last post by antonevane
- 15 Replies
- 6815 Views
- 4556 Views
Last post by ajwsurfer
- 890 Views
