I had just replaced the camshaft position sensor due to the car just cranking without starting. Upon replacement it start at first try. This worked for about two days, while driving the car it hesitated like it was going to stall but didn't and drove just fine. The next day back to just cranking without starting no spark. My question is what's the chance of getting a defective CPS or could it be something else
Thanks
1994 850T Defective camshaft position sensor?
- Has thanked: 311 times
- Been thanked: 817 times
My gut says more likely something else, have not heard of that problem, but what brand is the CPS?
Is the fuel pump working during these no-start episodes?
cBobs94850T
- Year and Model: 850 1994
thanks erikv11
the cps is a Bosch unit... the fuel pump is working fine
cBobs94850T
Conclusion to issue.. ervikv11 was right it was something else, in my case it was the electrical connector on the back of the air filter to the vacuum lines had come was off ( I guess I didn't put it back correctly) upon seeing that I reconnected it and tried to see if it would start took a couple of tries but it fired off and had been fine since. So it appears that connector off will give the same impression as a failed CPS the engine will just crank and not start.
- 1412 Views
Last post by cn90
- 2617 Views
Last post by Luzanov345
- 538 Views
Last post by jackissocool
- 1199 Views
Last post by Ozark Lee
- 1842 Views
Last post by batman00024
