2002 S60 car runs for 2 seconds and then stops
rohran
Year and Model: 2001 T5
Post by rohran »
Thought you guys might appreciate knowing this. The computer wasn't all the way in. The pink slides were about a quarter of an inch back. It would crank and start, but then die after 2 seconds... I didn't have the right tool to put the computer in. I was just using a screwdriver. Also, My scanner was complaining that it couldn't talk to the computer. I'm guessing that it will now.
High fives, anybody?
Richard in Provo, Utah
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Glad you solved it. Looking at your post title I was going to say that your MAF was bad. Did this on my XC90. So for those that look at your post and did not play with the computer. Check your MAF, unplug it and see if the car starts, if it does replace your MAF.
Has thanked: 1609 times
Been thanked: 4063 times
Im the "its never the computer guy" so I have an interest here.
Did this work its way out or had someone serviced it?
High FIVES ...and HIGH PI tomorrow!!!
rohran
Post by rohran »
I had to take the computer out in order to swap the engine. I didn't have the Volvo tool to put it back in, so I worked it in with a screw driver, but not far enough
Aha...my paradigm is thus protected.....
