'99 S70 -- Back Seat Removal
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I'm sure this is incredibly intuitive, but I'm just not feeling it. I've got to swap out the rear seat in my S70, but can't figure out how it is mounted to the car. Any tips/pointers out there for pulling an S70 rear seat? Thanks again.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 2202 times
Had to go refresh my memory on this. You pull up on the front of the lower seat cushion, and it should lift up from the catches and then slide out.
The backrests need to be un-latched from the upper latches and then there is a catch on the inner rear wheel arch on either side which needs to be raised allowing the backrests to slide inward to allow removal. Don't have a car to take photos of the process. Info courtesy of a well known DIY manual that is useless for most things, but may have finally found a sue for!
- E Showell
Thanks, Neil. I'll give it a try and report back.
'95 855 auto (sold)
'95 855 auto (sold)
I was slightly wrong on this part for the backrest removal. The rear seats have a catch accessed from the trunk side, and this needs to be in the raised position.
Then having released the backrests using the inner latch on the top of the backrest, you need to slide the seat to the OUTSIDE of the car and lift at the same time to allow the pin to release and allow the seat to be lifted up and out.
If you still have problems let me know.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I swapped an interior today.
- Been thanked: 4068 times
This topic has been duly MVSpinnered.
- E Showell
Wow -- That's almost as tough as a head swap. . . (Mine for Robert's).
'95 855 auto (sold)
'95 855 auto (sold)
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Robert, Is it this easy on a V70?
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
- rspi
Contact rspi..
LOL, Hel% no. Took me 2 years to figure it out.
[Youtube]
[Youtube]
- 2037 Views
Last post by 850forum
- 617 Views
Last post by BEJinFbk
- 516 Views
Last post by Clemens
- 2703 Views
Last post by MoVolvos
- 2315 Views
Last post by EuroTrash45
