2000 S80 Automatic gearbox selection problem
jh berning
- Year and Model: s80 2000
Hi, I have a Volvo S80 2000 model. the problem that I have is when I drive at about 80km/h the gearbox engages 4th gear and immediately kicks back to 3rd gear. At this speed it keeps on shifting between 3rd and 4th gear. Above 100km/h it stays in 4th gear and seems to have no problem staying there. Driving it in manual there is no problem. What could be the problem?
maybe dirt in a solenoid valve?
try draining the fluid and filter change
it will change out about 1/2 of the fluid
also maybe change rear fluid as well
they sell kits to do this at FCP or IPD
make sure you use the proper fluid...DEX VI for a GM tranny
when I did this, I replaced the 1/2 fluid with Castrol synthetic DEX VI and didn't have a problem
the synthetic is a good detergent to clean things out
I now am at full synthetic...having sucked a liter-at-a-time out, over a year's period, replacing it with the Castrol
smooth as butter
also, read up on the horror stories on this forum of people switching to synthetic before you do this
smooth as butter
- 698 Views
Last post by cuhfs
- 1146 Views
Last post by SuperHerman
- 1365 Views
Last post by matthew1
- 882 Views
Last post by JRL
- 1344 Views
Last post by bmdubya1198
