Gentlemen-
I am having intermittent #5 misfire and I have done EVERYTHING,(cap,rotor,plugs new plug wires, compression test) and have finally come to low fuel pressure, IPD says 43 lbs per in. at the Schrader Valve, yet Chilton says for a 1998 2.3 T5 is 58 lbs per in. What I really, really want to know is WHAT is the correct pressure?? I have a 2.3 T5 motor in a 1998 S70 with some minor upgrades and other than this problem the car flat RUNS.
Thanx, S70fanman
98 s70 Need to know CORRECT Fuel Pressure
- Year and Model: Many Volvos
- Been thanked: 76 times
43 psi is the correct number for a '98. Actually it is 43 and a decimal since it is converted from a factory spec that is in BAR. The accuracy of most pressure gauges is suspect so a number that is in that general area is good enough.
A fuel pressure problem wouldn't limit itself to cylinder 5, it would be across the board.
precopster
- Year and Model: Lots
- Been thanked: 128 times
Swap injectors from 5 to another cylinder and see if the misfire moves..
- 16134 Views
Last post by Richard99
- 2925 Views
Last post by Lucidsounds
- 771 Views
Last post by JRL
- 7954 Views
Last post by adrian22
- 3182 Views
Last post by mctee
