1999 V70 Rear Upper window trim clips?
paredown
Year and Model: 1999 V70
Been thanked: 2 times
Post by paredown »
I cannot make out what part number these clips might have on the Volvo diagram. Any help would be appreciated
They are the first clips on the large trim piece that runs from mid body height at the hatch and along the headliner. At the very top section there are larger saddle clips; at the tailgate edge there are metal clips, and these are the three that are in the corner along side the speaker.
They slide into the body metal, and they are a saddle style that a molded rod/barrel on the back of the trim piece snaps into. (both of the ones in the picture have one 'wing' broken off...)
I think at least one was broken before I started, but I had to remove the trim to get to the hatch struts. I put the three good ones on one side and hope I can find replacements for the other side...
1999 na 2.4l V70 beater--donated to Habitat in running condition
Has thanked: 2199 times
Been thanked: 1851 times
I believe they are part #29 on this linked drawing and called an "Anchorage"
Part #: 3511426
paredown
Post by paredown »
scot850 wrote:I believe they are part #29 on this linked drawing and called an "Anchorage"
Part #: 3511426
Thanks!
That's the top wider ones--but that drawing is much better than whatever I was looking at. The ones I need are #24 on the middle drawing or part # 3539879--you can see them indicated as attaching down beside the speaker opening.
I found someone in Europe that sells them where you can see them clearly:
http://www.skandix.de/en/spare-parts/bo ... l/1030521/
