1998 V70R Silver for sale - $1,200 184k miles SOLD
jmailloux
Year and Model: V70R 1998 Silver
Post by jmailloux »
For Sale:
1998 V70R, Silver exterior with Black/Gray interior, 184,000 Miles. $1,200 OBO
Selling because the family, dog, and skiing gear need more room and it has a transmission leak that I am not sure I want to fix. If it were not for the fact that I need something bigger for the road trips, I would fix the leak and keep it. It has been a great car and I am a fan of the V70Rs.
Highlights:
San Diego car (not at the coast), I have owned it since 2000 (second owner), and kept it garaged, no rust.
VIN: YV1LW5249W2435924
- Factory 3rd row seat, with the seat belts, all works fine.
- OEM stereo with 3 CD changer
- cargo area privacy cover (Volvo) will be included, just not installed for the pictures
- Factory 16 inch wheels, in good shape, minor curb scrapes.
-Excellent maintenance, all kept up. Mostly stock still, with a few exceptions below. Everything works, except rear passenger side courtesy light, and I just have not bought a bulb for it yet.
- Kept waxed, paint in good condition, the usual minor rock dings on the hood, which I have kept touched up.
- all new PCV system parts in 2014 (intake manifold off and all that under there replaced).
- most vacuum lines replaced at various points.
-New Nivomats rear with new shock mounts, new rear springs and bumper stops, and Bilstein TC front struts with IPD heavy duty spring seats in 2012
-New Continental Pro Contact tires in 2012 at 160kmiles, 205-55/R16, lots of tread left
-IPD parts: boost gage, turbo control valve, compression bypasss valve, phenolic spacer on intake manifold, upper engine mount bushings, lower engine/xmsn mount
-K&N Air filter
-Rebuilt propshaft from Colorado Driveshafts in 2013.
- AWD works fine; Angle gearbox fluid drained and flushed last in 2013. Minor seep at seal, mechanic has looked at it, no issue.
- A maintenance spreadsheet is available that I used to track all the maintenance if you want to see it.
Some of the other items replaced at various points:
- brake lines at the wheels
- turbo oil return line seal
- Oil dipstick seal
- camshaft oil seals (both)
- Oil cooler hoses
- all flexible cooling system hoses and heater hoses
- timing belt every 70k miles
- Steering rack
- inner and outer tie rods, control arms
- alternator
- ignition switch
- radiator
- ABS module (rebuilt)
Lowlights:
- The transmission fluid leak: From the same spot you would get a rear main seal engine oil leak, just the same seal on the transmission side. Red fluid leaking out, transmission fluid level goes down, etc. I have kept the fluid up, so transmission is fine and shifts well, but now leaking about a quart every 200 miles.
The independent Volvo mechanic I see for heavy maintenance has estimated at $1,200 to $1,500 to pull it all apart, replace the rear main seal (since we are in there) and fix the transmission side seal, and also replace any other seals that are accessible once the transmission is out.
If you have questions, please ask. I have many pictures, did not post them all, but I can add more if you want to see more.
The leak:
_____________________________
1998 V70R Silver 180k
jmailloux
Post by jmailloux »
Some things I can add:
Oil changed every 4k to 5k miles (I used 4k interval some years, 5k with Mobil 1). Mobil 1 for most of the time I have owned it.
Serpentine belt tensioner replaced a few years ago, new belt last year
Coolant flushed, new coolant and new thermostat in 2014.
And I will lower the asking price to $1,000 (thanks for not calling it out as too high).
Really a good car for someone willing to do the leak fix.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Can't believe this car is still available. If I was within 8 hours of it I would have contacted you the day you listed it!
jmailloux
Post by jmailloux »
erikv11,
Thanks for the compliment on the car. It is a really good car...just have to ask yourself if it is worth around $2,500 or $2,700 total (purchase price plus the $1,500 repair it needs).
Jim.
atomicthumbs
Year and Model: 1998 V70R
Post by atomicthumbs »
I've put down a deposit on this :D
Post by erikv11 »
Woo hoo!
atomicthumbs
I have the car.
It drives like a charm, except for the smell of hot ATF. Gonna get that seal done... as soon as I can get a set of sway bars so the mechanic can have something to do while the transmission's out. Gotta tame that understeer!
Er, not "tame". What's the opposite of tame?
In any case, I've got the car after finding a shipper in the nick of time. I've been looking for a 2.3L P80 car in good condition for over a year now, and I finally have one, and it's everything I'd hoped it would be. I plan to keep it mostly stock, with a few handling upgrades and maybe an ECU tune someday, and hope to keep it in as good condition as it is now.
I don't have a garage (yet), so the first thing on my list should probably be a cover.
jmailloux was responsive and a pleasure to do business with, too! :D
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
I though the v70 R was only 99+? Looks beautiful. worth the repair price even with the gearbox reseal
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
Post by erikv11 »
V70R is 98+.
srivera611
Post by srivera611 »
IS THE CAR STILL AVAILABLE?
