SC-816 front-to-rear fader control is cutting out right front and rear right speakers.
Is there a way to fix it?
2000 V70 speakers cutting out SC-816 - bad fader
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
You could try spraying one of the "contact cleaner" sprays in the fader slot to see if that helps. I've used "Deoxit" and the CRC contact cleaner with good results in some cases.
Another alternative is a trip to the junkyard, where the SC816 unit can be found in many of Volvos from 1995-2000.
- jreed
Sounds good. The CRC 2-26 is the stuff I've been using too. It's so much less expensive than the Deoxit and seems to work pretty well.
- 942 Views
Last post by Hardtofool
- 1907 Views
Last post by cn150
- 12 Replies
- 2897 Views
Last post by ferocity02
- 1916 Views
Last post by ElVee
- 23 Replies
- 3125 Views
Last post by azureblue
