1993 850 Fuel system diagram?
kludge
Year and Model: '93 850 GLT
Post by kludge »
You'd think that with all the information out there I would be able to find clear, labelled diagrams and photographs, but no.
As mentioned in my first post a couple weeks ago, I have a gas "tank" leak. I don't think it's the tank, but when I fill past ~15-16 gallons, the gas runs out.
I don't think it's the filler neck gasket or clamp. I did find one rotten hose above there. I'm not sure, but it appears to go back up parallel to the filler neck. Perhaps a vent?
Anyway I need a diagram with names so I know what parts to buy/order as I find them. Any links that you guys have?
I also have to go into the trunk and take a look at the condition of the hoses there. Runs fine, but I will change the fuel filter as a matter course. No markings on date or mileage when it was changed last.
Slight gas smell when I drive with the rear windows or sunroof open.
TIA.
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
Try this link:
http://www.volvopartswebstore.com/showA ... evel=24645
If that isn't what you are looking for go to www.volvopartswebstore.com and browse through the categories for your vehicle.
Good luck.
kludge
Post by kludge »
Thanks! The mess of hoses by the filler tube aren't labelled and almost looks like one octopus part. But there may be enough detail there to trace things out.
shaker_chi
The drawings are pretty detailed and have part numbers assigned as well in case you need to order anything.
