1992 850glt a/c relay positions
joer
Year and Model: 1993 850 glt
Post by joer »
hi i have a 1992 850glt the a/c just quit no lights on the climate control so pulled the manual out but not sure how accurate the diagram is noted there is a overload relay that must be closed thought i would check it first but the manual only shows where some of the relays are under the bonnet but doesn't label which ones are which i know i have seen a relay position diagram showing all relays and labelling them so i'm wondering if anyone has any info in this regard or any idea where i need to be looking any help would be appreciated thanks joe
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The overload relays are under the cover for the fuse box and they are the small relays that have a J printed on them.
Has thanked: 1609 times
Been thanked: 4065 times
Welcome to MVS Joe.
Please break up your sentences with punctuation and paragraphs per terms of MVS.
I'm not sure the control panel is fed through the big relays, but the wiring diagram would confirm that.
