850 stuck in park with ABS light on
Kevin850
Post by Kevin850 »
Every so often when I start my 850 it is stuck in park with the ABS light on. Usually I shut it off and re-start it and everything is fine. Now re-starting is not working and I end up using the shift override to get it in gear but then I don
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2653 times
Been thanked: 1247 times
Post by matthew1 »
Sounds like PNP switch.
https://www.matthewsvolvosite.com/forums/search.php and enter "shiftlock" for more info.
Volvospeed.com I believe has a how-to on fixing it.
Also -> Amazon link
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
[quote="Kevin850"]Every so often when I start my 850 it is stuck in park with the ABS light on. Usually I shut it off and re-start it and everything is fine. Now re-starting is not working and I end up using the shift override to get it in gear but then I don
