S70 T5 Timing Belt Job OFF
volvo_bruh
- Year and Model: S70 T5 1998
I spent all night replacing my timing belt. Had to keep alligning my cam gears correctly. Buttoned everything up after I thought I had the gears and my crank aligned properly. Turned it over a few times by hand. Gets hard to turn in some spots and much easier in others. Went to start the car and nothing. Wouldn't crank. So I let it alone and tried to crank it by hand again. Checked my crank alignment again and it was off. Have I hurt my engine at all? It never started or tried to. Just made a click noise. Any advice would be appreciated.
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
"Just a click sound"; sounds like a weak battery. I hope your alignment is not off, otherwise you must correct that first while the battery is being charged.
98 S70 T5-M Brick for life
- Been thanked: 4064 times
Take all the spark plugs out and try turning by hand again. The hard to turn spots should be gone. I don't think you can turn the engine over by hand if the valves are hitting unless you are Schwarzenegger, so don't worry!
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
When you crank it by hand, try to use a break bar if you can or add a pipe to ur ratchet to get more torque. That's normal for the engine to be hard to crank half way through. LIke the previous post, take the spark plugs out and it will be much easier. If you don't hear anything you should be fine.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Get a bud with his car and connect both terminals to your battery - very careful not to touch them together or to some other metal part, install them one by one.
Be sure to have the ignition key in position II when connecting the battery.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Why?oragex wrote:Be sure to have the ignition key in position II when connecting the battery.
It doesn't matter.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2197 times
- Been thanked: 1851 times
And don't connect -ve to your battery or you could fry the electronics. Attach the -ve to an engine earth.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Can you post a picture of the alignment?
obayha
- Year and Model: V70 1999 Base
Looks like he is saying he tried to crank the car and it didn't crank. Wouldn't crank over or wouldn't start?volvo_bruh wrote:I spent all night replacing my timing belt. Had to keep alligning my cam gears correctly. Buttoned everything up after I thought I had the gears and my crank aligned properly. Turned it over a few times by hand. Gets hard to turn in some spots and much easier in others. [Went to start the car and nothing.] Wouldn't crank. So I let it alone and tried to crank it by hand again. Checked my crank alignment again and it was off. Have I hurt my engine at all? It never started or tried to. Just made a click noise. Any advice would be appreciated.
You shouldn't be able to turn the engine over by hand cranking, if the valves are hitting, but if you used the starter, it might be enough to bend a valve if not aligned right. You checked the alignment after trying to crank and it was off. Did you use the starter or hand turn the engine?
I might be reading this differently than the others.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- 5228 Views
Last post by jimmy57
- 23 Replies
- 17044 Views
Last post by jonesg
- 2267 Views
Last post by sleddriver
- 28 Replies
- 4257 Views
Last post by erikv11
- 71 Replies
- 12514 Views
