The up and down function and memory function works, but it is stuck in the fully declined position and will not move. When you press the button it clicks, but nothing happens.
thanks
2001 S80 Drivers Seat will not incline
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Sounds like the button works, so it's either the control module or the motor. Take a look underneath make sure motor plug is fully seated and there's no corossion at the plug. I'd get a wiring diagram and check for voltage at motor connector when pressing switch. If voltage present motor's bad. If no voltage at motor when pressing button then the control module or harness are defective.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
draser
I'd try a salvage yard. May not be able to replace motor so you may have to go with full seat and swap trim/foam. Hopefully it's module or wiring.
- 254 Views
Last post by 5underpressure
- 1886 Views
Last post by 1bigklutz
- 1001 Views
Last post by jbkeene
- 2470 Views
Last post by Bmcclure
- 894 Views
Last post by Volvo S80
