Will this gauge work on the 850's?
http://www.harborfreight.com/catalogsea ... l+pressure
Any Volvo Question about HF fuel press gauge
- Has thanked: 2200 times
Assuming you mean the $20 version, provided it has a threaded end that can screw onto the Schraeder valve on the end of the injection rail it should be ok, and if it has a range covering 3-4 bar, or 40-65 psi you should be good. Any other opinions guys?
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Why's that? I have a T5 with the TB under the manifold, and I seem be having fueling issues. If I have to drop the ETM to check fuel pressure, I'm going to push the car off a cliff.tryingbe wrote:One must take the throttle body off before doing any fuel test.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I found this You Tube vid that shows how to use a standard pressure gauge and length of rubber fuel line. Also, answers the question about what to do with the schrader valve—remove it during testing. The demo doesn't mention if fuel gets into the pressure gauge. Guess I'll find out.
Seems pretty simple.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
on 850, bracket is in the way.j-dawg wrote:Why's that?tryingbe wrote:One must take the throttle body off before doing any fuel test.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
j-dawg
Phew.
I rented a kit from Autozone, and it costs a $160 deposit. I'll get it all back when I return it, and I wanted it this weekend, but I feel like I'd rather pay $20 and get a crappy HF tool that I can keep, even though I'll only use it on occasion.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The O'rielly kit did not work on 2001 V70XC.
There was not enough room to connect on '97 850 -- the bracket is in the way.
I would like to know how your's go?
Will you test the fuel pressure regulator?
j-dawg
I'll post results when I get 'em, probably this weekend.
The car's been behaving strangely lately, and I'm no longer so sure it's fueling-related. We'll see.
- 6453 Views
Last post by 93Regina
- 612 Views
Last post by paul850
- 1934 Views
Last post by rspi
- 453 Views
Last post by Ozark Lee
- 23 Replies
- 5879 Views
Last post by bluesguys80
