1994 855T 143 code and boost
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
Now that spring is here, I can sort out my 143 (front knock sensor signal) code. I have not started on it yet, but it looks to me that I will have to pull the manifold to visually inspect the sensor, and replace it, if needed. Please correct me if I'm wrong, though. I am hoping it is a bad connector, but I haven't gotten under the hood to locate it - I hope that doesn't require pulling the manifold..
One other question - will a code 134 keep the boost down? I am assuming it will - the timing would be pulled back to protect the engine, but I don't know enough to know if the other knock sensor is the back up..
Thanks in advance for any advice.....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
