Hello,
I have not posted in a while, but wondered how easy radiator replacement would be in my 98 S70 Non-turbo, and it looks like there are two different ones. One with male and one with female couplings. Is there an easy way to tell without pulling the radiator first? Any help would greatly be appreciated. Also, any recommendations on the most budget friendly radiator and what tools might be required. Thanks in advance.
1998 S70 Radiator Replacement- Male? Female?
roscoerich
- Year and Model: S70 1998
RoscoRich
1998 Volvo S70
1970 MGB Roadster Right Side Drive
2006 Hyundai Tuscon
1998 Volvo S70
2006 Hyundai Tuscon
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Radiator replacement is very easy. I followed FCP's video ->
Robert also has a nice video detailing the replacement ->
I used a radiator from 1-800-RADIATOR. They offer a lifetime warranty and had it delivered to my house in a few hours. You'll need basic tools, nothing fancy required.
- Has thanked: 2200 times
You asked which radiator you need. Normally for a 98 you have the older couplings which have a metal 'cage' over them. To remove you need to open the cage with circlip pliers and then the pipe pulls out. I guess you'd call the pipe a male end as it pushes into the coupling on the radiator.
I can't recall on the N/A engine, but I don't think it has an oil cooler in the radiator which has 2 matching connections on the RH side of the radiator (alternator end). I think that is only on turbos.
Technically you could use a turbo radiator on an N/A but not the other way around. You just wouldn't need the connections on the RH end.
99> have a different connector I believe (certainly my 2000 has).
This should be what your radiator looks like. Idiots show the radiator upside down!
https://www.fcpeuro.com/products/volvo- ... on-turbo-1
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
My '98 is engine #1175,xxx and it has the female fitting on the radiator and uses the metal clip lock. Change out through the top is definitely the way to go on an NA--fairly easy task.
- 3105 Views
Last post by sleddriver
- 1422 Views
Last post by tehniemer
- 3567 Views
Last post by t3yf5g
- 7141 Views
Last post by jalwlb
- 123 Views
Last post by volvolugnut
