1998 V70 AWD so it has the 2.4 turbo.
Misses under light load, typically on deceleration. Typically going form 1,500 rpm down. Sometimes stumbles on acceleration. Sometimes dies at the light. Idles fine upon start up. If stumbles, I can keep it going by accelerating.
Replaced plugs (NGK copper to .28), wires, cap and rotor.
Ideas?
98 V70AWD Missing on 4,5,random - replaced plugs,,wires,cap,
Andrew Vanis
- Year and Model: 1999
- Been thanked: 11 times
1998 V70 NA (11/97 build date) 230,000mi
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Andrew Vanis
300 = random/multiple
304 = cyl 4
305 = cyl 5
304 = cyl 4
305 = cyl 5
- Has thanked: 311 times
- Been thanked: 817 times
Try cleaning the Idle Air Control valve.
Other possibilities that come to mind: throttle position sensor going bad (difficult to troubleshoot), MAF going bad (but usually gives a code, easy to test by unplugging it), fuel supply (furl pump relay, less likely fuel pump).
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Hate to say this, but these cars are very picky when it comes to plugs. I would try a set of O/E Volvo plugs. Also, what brand wire set did you put in? Was it 7mm or 8mm? Before you go spending more money though, I would do a thorough check of the wires to make sure you have a good connections.
Very picky about plugs yes, but NGK coppers are known to be a good choice.
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
If misfire is consistent on those 2, did old plugs look different than other 3? Maybe whiter or more fouled? Are you loosing any coolant?
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
Andrew Vanis
after exhaustive diagnostic, the ECU appears to be bad. Was told to look for a replacement. Have a separate post on that here - https://www.matthewsvolvosite.com/forums ... =1&t=69789
wondering what other years / models I can pull one from.
- Been thanked: 504 times
As mentioned above.
Plug: NGK or Bosch
Cap/Rotor: Bosch only!
Ignition Wires: Bougicord only! Make sure they are installed in the correct order!
Plug: NGK or Bosch
- 5556 Views
Last post by SwissXC90
- 12 Replies
- 1667 Views
- 1239 Views
Last post by Roger_850T
- 14 Replies
- 3996 Views
- 870 Views
