Unless I pull fuse #37 Injection System under the hood. My battery goes dead with in a day.
If I pull it battery never goes dead. Any ideas?
2007 S80 Battery Drain Fuse 37
manitouboat
- Year and Model: S80 2007
New battery. Charging up to par. I 'm absolutely sure that it has something to do with Injection system fuse #37. there is a high pitched whine under the hood after the key shut off. Until I pull the fuse.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Close the hood latch on driver's side and lock the doors. Listen again after 4 minutes and see if the noise is gone. Until the network shuts off all modules you could have the TCM pulsing the STH solenoid.
You really need to measure the current draw with an ammeter. You will have to fashion a way to leave battery cable connected initially with an ammeter also in place between ground post and ground cable. After 4 minutes pull the cable leaving only the ammeter leads connecting ground post to ground cable so you can see what the current usage is. If you have access to an accurate inductive amp probe then the battery cable fuss is not needed. The initial current draw key on and in the first minutes after key is switched off are too high for direct amperage measurement as it is usually more than the 10 amps the meter and its leads can handle. Once you see the load then you pull the fuses that are powered as measured using a voltmeter and you should know which circuit is staying live. Your issue could be many things including a faulty module that does not go off when signaled. A door latch (hood and truck too) not having a switch that goes to closed position when shut can also cause high current draw and not always leave a light on as evidence.
- 776 Views
Last post by Skymongrel
- 2203 Views
- 14 Replies
- 922 Views
- 2428 Views
Last post by Vova585
- 11 Replies
- 3504 Views
Last post by cn90
