2003 V40 Transmission filter blocked
volvogrl15
- Year and Model: 2003 V40
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
- Been thanked: 2 times
Check for fault codes.
Could be shift solenoid problems?
Have you checked the transmission fluid level and is it reasonably clean?
difflock54
You won't have a filter inside the transmission at all but there may be an inline filter setup on your oil cooler return hose. (i.e. magnafine filter)
precopster
- Year and Model: Lots
- Been thanked: 128 times
There is in fact a filter at the base of transmission but is not accessible unless casing is split and there is no pan. It won't be blocked as it's purpose is to collect sediment and it doesn't impede fluid flow regardless of contamination.
Sounds like a fluid change/fluid level check may be your last hope before sending it in for a rebuild.
- 1202 Views
Last post by Nismou20
- 826 Views
Last post by oragex
- 54 Replies
- 10498 Views
Last post by cfelberg
- 2895 Views
- 3913 Views
Last post by xiaofei204716
