92 740 Turbo Wagon Antenna Mast
Dalpatine
Year and Model: 92 740 Turbo/ 93 940
Post by Dalpatine »
Alright,
I am wanting to replace the stationary antenna the previous owner installed after the retractable antenna broke. The motor still works when the switch on the dash is operated and I ordered the replacement antenna from iPd. However I am noticing some differences in the diagram from their online instructions and what I am seeing in my wagon. For instance I'm not seeing a ground wire or the relay shown on the instructions. I am thinking that this might be because the instructions in the PDF file are for the sedan version and the wagon layout might be a little different. I want to make sure I do this right so I don't mess anything up. Any tips or explanations for the differences I am seeing? Is it because the instructions are for a sedan instead of a wagon? If so it shouldn't be a big deal. Looking at it I think the relay and ground wire would be the black box shown on the pic below. Let me know if I am completely off.
Here is what I see:
Here is the link to the online instructions:
http://www.ipdusa.com/products/4972/102 ... for-wagons
Dalpatine
-1992 Volvo 740 Turbo Wagon
-1993 Volvo 940 Wagon
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
When I swapped a newer power antenna into my 1988 Volvo 760 Turbo wagon I had to swap some of the electrical parts from the old antenna.
1988 Volvo 760 Turbo Wagon
Dalpatine
Post by Dalpatine »
Any help on how to remove the interior trim to access the antenna tube that would be great!
Dalpatine
Dalpatine
Post by Dalpatine »
I did not feel confident in removing the trim so I am having a local shop do it at my next servicing.
Dalpatine
lummert
Post by lummert »
The clips holding the corner trim piece are most likely going to break, whether you do it yourself or someone else does it.
