Key On - No Warning lights
Engine Idling - A dim battery light, fuel/temp gauges do not work...battery voltage 13.8V
40 MPH Driving with OD engaged - Speedometer reads 20 mph
40 MPH Driving without OD - Speedometer reads Zero, battery light bright
1993-240: Electrical SNAFU
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Update:
After taking a 10 mile highway drive, I disengaged OD, and fuel/temp gauges began working, and speedometer went to traveling speed.
Back to normal now!
I fail to see how that OD Relay is related to this SNAFU, but somehow it is.
Back to normal now!
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Does this car have a main head light relay similar to the one used on 88-90 760 and 92+ 960? The main relay on my 88 760 is rectangular about the size of two standard relays. When this relay was failing on my car I had all sorts of electrical problems. The head lights randomly wouldn't come on, the speedometer would randomly stop working when the head lights were on. The overdrive light would be lit even though it shouldn't have been. Replacing this relay with a spare solved the problem.
1988 Volvo 760 Turbo Wagon
- 93Regina
Several months ago, I replaced this relay with a VOLVO 1307991 GENUINE OEM RELAYlummert wrote:Does this car have a main head light relay
When I clicked the OD button to disengage, it was instantaneous, everything back to normal.
Quartz clock worked fine, all of the time.
- 93Regina
Symptoms:lummert wrote:Does this car...
1. OD Engaged - OD and battery lights were dimly lit; No temp reading, and a pinch on fuel gauge
2. When key switched to on position, all warning lights off.
3. Non OD Mode - Only battery light glows brightly, nothing else works on dash except clock.
Solution - Maybe fuse 16 was the issue. I cleaned its terminals, and fuse's ends
16 Parking lights (right side), Instruments and control panel lights, Shift indicator light 8A
- 93Regina
That's an idea....I need to study/think about that OD Relay...when issue happens, it is dimly lit with OD engaged, and brightly lit when OD is off.5ft24 wrote:Check grounds to the instrument cluster
OD Relay provides a ground path for bulb to light up when OD is not engaged, which would suggest there is power on the bulb side.
Alternator light is lit up when this issue happens, which would normally mean the alternator is providing the ground path.
One of these days, I'm going to remove instrument cluster and fix Odometer.
- 2601 Views
- 618 Views
Last post by Georgeandkira
- 1936 Views
Last post by socalvolvo
- 630 Views
Last post by Love2FlyJets
- 873 Views
Last post by e777
