2000 S70 Lug Nuts Coming Loose
Eddienorgard
- Year and Model: 2000 Volvo S70 SE
- Been thanked: 2 times
Hello! Having something weird happen with my driver side front tire. I switched around tires on my car after having a blown out tire replaced. (switched the tires to have the newest wheels in the front and older wheels in the back). I did all the tire changes myself. After driving for about 40+ miles a violent shaking was coming from my front driver wheel. When I checked the lugs, they were COMPLETELY loose. Almost ready to fall out, loose. Pretty scary because If i had driven a little more the wheel would have fallen off most likely!! I tightened the lugs and after driving another 40+ miles the shaking came back! Checked the lugs again, they were loose! Why is this happening?? All the other wheels were changed at the same time but none of them are experiencing this issue! Any ideas?? My only guess is that I had once asked a garage to make sure I could loosen the lugs on this specific wheel after being forced to bring the car to this garage after I could not get the lugs out. It appears that this grey grease was applied to the lugs... Maybe this is it? But looking for any sort of advice or experience with this issue!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Maybe there is antisieze on the threads. Pull then one by one and clean them with brake parts cleaner. Also spray the hub threads clean. Then turque them down and check them over the next few hundred miles.
- Been thanked: 504 times
I have used anti-seize for 30 years with none of these issues.
Check the threads on the lugs and the hub side, perhaps some threads are stripped from over-tightening in the past?
Eddienorgard
cn90 wrote:I have used anti-seize for 30 years with none of these issues.
What should I do if the threads are stripped?
difflock54
- Year and Model: V40 Nordic 2002
- Has thanked: 7 times
In most cases where the threads are stripped one can remove the lugs and fit new ones to the hubs.
They have splines (tapered?) which are fitted via the rear face of the hub and pull up tight when torqued up with the wheels fitted.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I have anti-seize on my bolts and no problem with it.cn90 wrote:I have used anti-seize for 30 years with none of these issues...
Just make sure that you torque them good and re-check with wheels on the ground.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jimmy57
- Been thanked: 322 times
Are you sure there are no replacement lug bolts with the wrong cone angle?
Compare the left front set with one removed from another position w/o the problem.
- 1233 Views
Last post by tle1288
- 1116 Views
Last post by RussB
- 11 Replies
- 4386 Views
Last post by beigg
- 23 Replies
- 10634 Views
Last post by zupta82
- 1237 Views
Last post by packetfire
