2006 XC70 Unique Electrical Issue
IdahoBob
Year and Model: XC70 02, 04 & 08
Has thanked: 1 time
Been thanked: 4 times
Post by IdahoBob »
I would appreciate any thoughts on where to start looking on this one... Bought a pretty clean '06 XC70 with 113,000 miles. California car, so little environmental damage other than some sun rot. The problem is electrical.
If I pull the handbrake on, the "check engine light" (CEL, hereafter) comes on. It goes off after about 20 seconds, whether the engine is running or not. If the car is off, and the CEL goes out, and I open the door, the CEL comes back on. If I leave the handbrake off when parking the car, no CEL. Possibly related, the rear fog light (that small vertical row of 5 dim bulbs, under the left rear running/brake lights) is always on anytime the engine is running, whether the switch is in the off or on position.
Thoughts anyone?
Thanks, Happy Motoring!
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
Has thanked: 1609 times
Been thanked: 4063 times
Yikes. This one sounds like it needs a Swedish exorcism.
The 2006 model is run by a host of computer modules which all talk to each other. You need this hooked up to VADIs to start figuring out what is (not) talking to what as a start.
When the CEL comes on you could try reading codes to start, but I bet there aren't any.
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
If you can't get to scan those codes I would start with brake pedal switch as it seems to be all around with your problems
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
This may be one of those instances where you might be money ahead in the end to go ahead and pay the dealer to scan the whole car and give you their diagnosis as to what may be at the center of all this. If, for instance, they come back with "faulty CEM", then you could send it up to Xemodex for a rebuild.
