I found a temporary wheel set for my cracked set on my 01 v70. They are size18x8...5x114.3...+45..will they fit? I dont know too much about wheel numbers.
thanks.
wheel size question
I know for sure those will not fit Volvo has a very specific bolt pattern, its 5x108 not sure the other number that you might need to match but those 5x108 need to match for sure
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
2009 Merz $550
2013 chevy 2500HD
JRL
- Year and Model: Several
- Been thanked: 16 times
You were just told
5 X 108
ET between 40 and 49 depending if you want to use spacers
5 X 108
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
You can mostly only fit Volvo wheels on these car, as mentioned above. Even from other recent Volvo models other than the V and the S40, as long as they clear the brake rotor (I think there is a 10" and a 11" rotors if I'm correct, the 11" will need 16" wheels and larger).
Thanks.
like i said im learning, i dont fully yet understand too much what all the numbers mean.
speaking of which what do the numbers 40-49 mean? And is it after 49 on whatever it is that i would need spacers?
- oragex
To have equivalent wheels, they must have 5 wheel lugs and the distance between two near wheel lugs center is 108mm. Additionally, we need a center bore - the whole in the center of the wheel - to be a specific size because it goes on the bearing on the car which has a center ring of the same exterior size. There is also a matter of what size are the wheel lugs, length, diameter and filet pitch. Then we have the wheel offset, important because it needs to clear the brake caliper; also the wheel diameter.
There are a few sites explaining in detail with pictures all these parameters. Also site for each specific car with the available wheel sizes but these sites have sometimes errors http://www.wheelfitment.net/volvo
precopster
- Year and Model: Lots
- Been thanked: 128 times
Centre bore is 65.1 mm on 2001 Volvo.
- 848 Views
- 2587 Views
- 1666 Views
Last post by precopster
- 1309 Views
- 1426 Views
Last post by Sannerdm
